Hi All,
New here and hoping someone might be able to help ID this prop. I checked the hub dims as suggested on the main page. Here's what I have…
• Number of Bolt Holes: 8
• Center Bore Diameter (metal): 3 1/8"
• Bolt Hole Circle: 8"
• Hub Diameter (metal): 10”
• Bolt Size: 1/2"
• Hub Thickness: 7” (approx)
• Propeller length: 144” (yes, 12' feet tip to tip)
Based on the chart - it could have been fit to a Liberty 12 engine
Also - found some very faint markings that are hard to make out.
N 734 (or possibly 1N 734) - smaller marking
3029 - large marking (each number is approx an inch tall)
And there appears to be makers mark (logo?) on each side of the hub on an oval shape that is flatter at the top. Almost appears to read STORY - not sure though.
Also, appears to be a pusher. I had thought it might have been from a float plane or air ship.
See photos below (Sorry I could not get one shot of the entire prop - will have to try again with a ladder)
• Bolt Size: 1/2"
