Hello! I have a Starr Piano Company propeller. The story behind it is not very well documented, so I was hoping that the propeller itself might give some clues.
From my records, the propeller was owned by a local doctor who served in WWI as a medical officer at several U.S. airfields. He apparently salvaged this propeller from a crash site at Dorr Field in Florida, after attending to the injured pilot. The doctor kept it as a souvenir and added his own picture to it on the hub.
The propeller is clearly marked "Starr, Richmond, Indiana" in two places (unfortunately, not very visible in the photos). It is 8 feet from tip to tip. There are no serial numbers, but it's possible those are hidden by the 6-bolt "picture frame" on the hub. (I don't plan to remove it to look, but I would be interested to know if markings might be hiding there.) The underside of the hub has 8 bolts, and what looks like 8 other bolt holes that have been drilled out and filled in.
Does the story make sense in light of the propeller itself? I know it's hard to confirm anything, but it would be good to know if there are red flags.
Thank you for your time and expertise!
