Could someone identify this wooden propeller?
Blades are shortened.
Diameter hub is 190mm
Axle hole is 60mm
8 bolt holes diameter is about 9mm
Hub thickness is 100mm
Markings on the hub are
AR
Rh 80
Serie 22201
Serialnumber 30350??? Hard to read
Thanks for all the info!!!!
Could it be from a Nieuport 10 AR????
Axle hole is 60mm
AR
Rh 80
Serie 22201
