My pappy passed away a few years ago, and I found this propeller dusty in his attic. He was a pilot for many years, and so was my great-grandfather back in the early days of flying.
I'm having trouble figuring out what this propeller is, since it has no obvious markings - and he never mentioned the propeller so I'm not even sure if it is real (or a very good replica). I looked through the specs and pics, and to me it looks very similar to the "Jenny" and I know occasionally he would talk about flying a Jenny - but I'm not an expert.
I took some measurements:
It is about 8 feet long from tip to tip. The tips are a little worn, so it is possible it was a little longer.
The center bore hole is 2 3/4 inches diameter and 4 1/8 inches thick.
There is no metal "hub" on it, but the center of the hub is 7 1/2 inches wide. It looks like it may have had some bolt holes, but it is hard to tell how many. It sort of looks like in the past someone may have filled them in or tried to refinish it (or, it is just a replica).
Any insight? Either way, I plan to mount it on my wall to display it - but knowing what sort of plane it was from or type of propeller it is would be interesting to know.
