I have a prop that used to belong to Canadian fighter pilot Lt. Henry Botterell of RAF 208 Sqn. Here is a link to a story about Lt. Botterell from a local newspaper . He was the last surviving pilot from WW1 and passed away January 2003 at 106 YOA.
The markings on the hub read:
LP2850
130CL
D2590
P2270
Hub diameter is 7 cm and the thickness is 15cm. The bolt circle diameter is 154 mm. There are no other markings I can see.
My internet search suggests this is a Lang Prop for a Sopwith Camel which was a plane Lt. Botterell flew. The prop measures 259 cm (2590mm) so the diameter must be the third #and the last one is pitch. Am I correct so far?
LP2850
130CL
D2590
P2270
