When you say "its history" do you mean what specific airplane it was mounted on?
If so, it's extremely unlikely that you will be able to find that, and in fact you might find that it was never even mounted on one. If you can post a photo of the prop and a close up image of the hub, we can probably guess whether it was ever used or not by the presence or absence of "witness marks" caused by the pressure plate of the metal hub assembly.
Photos of the entire prop, the markings, and decals would also be useful.
The G number you have given us is a batch number. G1456 dates the prop to late 1919 or early 1920. These batches contained 100 props so yours was number 85 in this batch.
We need the data stamped on the sides of the hub to give you any more info.
I will post photos asap
I found more lettering on the other side
not 100% on all the letters but something like as follows
DE H9
200 HP SIDDERLEY
13HP
DRG 8B 7031
D 2750
P 2530
A picture of the stampings will help. It's almost certainly "AB" (for "Air Board") rather than "8B" for instance, and I can't imagine what the "13HP" would signify. I'll look through my reference materials when I get home (including Bob Gardner's books) which should help fill in some gaps.
In the meantime, you can at least confirm the accuracy of the "D" number, which should be the length from tip to tip in millimeters.
This prop has been in the shed since I was little. I have bought it in the house now and would like some advice on cleaning it. It is dirty. I have it stood on some foam to try and protect tip and will hang it later. I don't want to ruin it at all and my dad always kept it untouched
My mum had the other prop which is polished and hung on wall, that is from a Sopworth camel.
"13HP" is likely to be "BHP" this came from Beardmore, Halford and Pullinger, 3 of the main men involved in the design and manufacture of the engine that this prop was designed for.
From the plate on the prop would that have been the last engine it was fixed to?. I was going to remove the plate but perhaps I could leave it on and clean it up a bit. It is very oily.
Typically, if the propeller still has the metal hub attached it's most likely that it was used on that engine, removed for some reason, and never mounted on something different. But there's no way to be sure of the exact history.
