Dear fellow aviation enthusiasts,
Let me first apologize for placing a first post in this forum, which again is yet another desperate cry for help about a propeller identification. Things are as such:
I am very much interested in Naval Zeppelins, which were of course equipped with Lorenzen, Garuda and Jaray propellers. Some time ago I ran into a dealer of old aircraft parts, who also sells a propeller which supposedly belonged to the L33, An R-type Zeppelin which was downed in 1916.
General details of the airship say that it was equipped with 6 Maybach engines and 6 Lorenzen props, all between 5000 an 5800 mm diameter.
The prop that I am interested in is only partially complete, it represents a single blade with the prop hub. The hub has been widened, to allow the mounting of a clock. The tip of the blade is missing aswell. The prop itself has been surface treated/sanded down around the hub, to give it a 'nicer' appearance (such a shame).
Imprints on the prop are:
ETA (imprint on the forward face of the prop).
4560. EDULZUG (so it's a tractor, whilst the zepp only has pushers?)
ST 265/30. (so the pitch is rather high)
310 ( with a theta symbol in front of it. Mind you the 3 in front of the 1 and the 0 is questionable and could be a 5 aswell)
So what we can see is that according to the markings, it was produced by ETA Luftschraubenwerke, and it had a diameter of just over 3 meter. Now I would immediately say that this is not a prop from the L33, but I am not an expert on this field!
I noticed for example that the Imperial War Museum has a prop from L33, which has a diameter of only 2740 mm (exhibit AIR 416), which doesn't match with my knowledge of L33's propulsion. Also, they specify two ETA propellers ( AIR 406 and AIR 403) as Zeppelin propellers, allthough to my knowledge Zeppelins never used ETA props?
As you can see, I am completely lost, I don't want to spend money on something which is not what I think it is, but I also don't want to let it go allthough it might actually be authentic. Any help would be appreciated!
Best regards from the Netherlands,
Marijn
Marijn
