New to this forum, but can anyone help with plans for a Renault 70hp LH 4-blade prop. They were around 8'6" dia. - it's for a BE2.
Or the same for use on an RAF1 engine. Thanks.
I don't have the plans. The model listed for that is T1453, was a 4 blade left hand tractor and had a diameter of 2740 mm and a pitch of 2570mm.
The RAF engine for that airplane was a 90 hp model. There were several different drawing numbers for that, including a 2 blade. Do you want those dimensions?
