I acquired a propeller tip as part of a trade the person I acquired it from is convinced that it came from a RAC fe8 a pusher biplane which had a 4 bladed prop .I am not familiar or knowledgeable in this field so took the collector for his word and it is only now I wish I asked more questions at the time .The blade also came with a section of clearly very early canvas which was either on the prop or from the plane .Online it is stated that a fe8 prop measures 240cms that is 7 feet 9 inchs my blade measures 90cms or 3 feet it also states that the blade has dowels that fix together the laminated sections and also the leading edge clearly has a different shaped metal covering on asking the collector about the different shaped metal edge I was told that there would have been different shaped leading edge covers over time .When I look at online photographs of fe8 props and orientate my blade tip to those seen it seems to me that my blade section is far too big i.e it came from a much larger prop than that of a fe8 if my prop is genuinely off an fe8 then according to my math and presuming all fe8 props measure 7 feet nine inchs then it would be a further 10 inchs to the very central hub / boss of the propeller ...this does not seem possible .
This is a link with details to a fe8 prop
http://woodenpropeller.com/FE8.html
As you can see my prop is clearly old quite as to why the previous owner is convinced that it is from a fe8 I don't know maybe he was told it came of a 4bladed pusher and that it came off a RAF plane .
I would be grateful for any advice and extremely grateful if this thread could be passed around the forum until I get to the bottom of this mystery I would also like to add that there are no markings on the prop.
One final thing I would like to add is I don't know if the measurement of 7 feet nine inchs of the fe8 prop is the measurement from one tip to the opposing tip or from the ground to the props highest point
