I would greatly appreciate any help identifying this propeller! Also looking for a value estimate..
The following is what is know about this propeller:
1.One side of the prop reads the following from left to right in a circle (as clearly as I can identify):
"HISPANO.SUIZA.180.H.P PART.N.O 067648 R.H.T.M OAK.PLATED.STANDING.RPM.ENG"
2.The opposite side reads (I'm barley able to identify the markings) what I believe could be:
"US 1427 X" or "US 1927 US" or something along those lines..
3.The dimensions are as follows to the best of my knowledge:
A. The hole in the middle is 3 1/8 inches wide.
B. The distance between any bolt holes from the exact center of the holes.(spanning across the middle) is 6 5/8 inches.
C.The total width of the entire main center area of the prop is 9 inches.
D.The widest section on the blade of the prop is 7 3/8 inches.
E.The total length from tip to tip is 104 inches. (8.7FT)
Also.. It looks as though there may have been some type of gold leaf or gold paint used on the lettering, or around the prop..
PHOTOS BELOW!!
THANK YOU!!
-Will Moench
PHOTOS BELOW!!
THANK YOU!!
-Will Moench
