Greetings Dave and Wooden Prop Fans.
I picked up this propeller about thirty plus years ago from an older/retired crop duster. He had told me it was quite special, but could not recall the airplane.
I would like to know if any one has knowledge or interest of this 11 foot prop.
I measured what I could and this is what I found,
The prop is approximately 11 foot from end to end, has brass plates on the leading edges and looks like lead was used to fill the dimples from the screws holding on the brass leading edges. The widest part of the 11 foot propeller is 11 3/4 inches and there is a number "2935" stamped or burned into the wood near the hub. I could not find any other markings on the wood, but the hub is still attached if this may help.
(1) The hub is 10 inches in diameter with a recessed machined ring cut 9 inches diameter just inside the 10 inch outside diameter.
(2) There are 8 bolt holes drilled in the hub at .620 for the (
1/2 inch diameter bolts that holds the prop between two pieces of hub.
(3) The 8 bolts look to be spaced at 3 inches apart
(4) There is one pin hole or dowel hole drilled at .350 into the hubs plate. between 2 of the 8 bolt holes )
(5) There are 8 larger (decorative) holes are drilled at 1.350 diameter between the shafts hub and the (
1/2 inch mounting bolts.
(6) On the convex side of the propeller,the hubs hole is smooth/maybe tapered and the shaft's size appears to be 2.4250 inside diameter. with a key way cut at .4850. (Looks like the convex side goes toward the engine)
(7) On the flat side of the propeller, the hubs hole is threaded and measures 2.500 inside diameter.
Hub is painted or primed a green color on the hub's threaded side, and there are (
1/2 inch splines spaced at .725 outside the threads.
See attached photos
(9) Photo # 2 shows the keyed/smooth side of the hub. (Concave) From the pilot looking backwards,and the prop was turning clockwise, it would make since.
(10) Photo # 4 shows the threaded side of the hub (Flat)
From the pitch of the prop to the hub's position, I think it may have been a pusher.
(All measurements are approximate)
Sure hope this info helps you to help me identifying this propeller and hub.
If you need more pictures, just email.
THANKS for all you do.
GARY HACKWORTH
530-260-4225
acenflygirl@frontiernet.net
See attached photos
GARY HACKWORTH
530-260-4225
