Hello All
Thanks for the great website and forum , I have got a good start learning about props from this site.
I have listed on ebay a Lang Products Co. prop that i would like to learn more about. I understand the common markings on it but there are other markings that i hope to learn more about.
There are alot of markings on this so I will try to go in some order , top of hub is marked " N 597 " and " TM ' which is also the only marking on other end which i believe stands for Tractor Monoplane , On the main face of the hub starting from left in photo is a navy " Anchor US " symbol then " MD " in a circle then " RNA " , Around the hub reads " DRG No S.E. 5090 , L.H. H.P. 370 Liberty Motor Lang Products Co. No 5440 , Pitch 6.65 DIA 8 - 4 " . Then there is " RDW " then two lines of words or letters i can't make out above " U.S. NAVY " . I tried pencil impressions and lighting and angles for an hour and its to weak to make out but first two letters looks like " M.T. _ _ _ _ "next line looks like " RES _ _ _ " then third line is " U.S. NAVY '. Interesting that this has two Navy markings and maybe what i cant make out refers to decommissioning. The back side of the hub has only one capitol " X " marked about 3 inches onto the wing at center from hub toward damage , which should be seen best with the zoom function in the 8th photo. There is cork filler in the mount holes on backside of hub. The hub is 8 bolt and aprox 12 inches tall 3 3/4 thick with a 3 1/4 opening.
I 'am interested in any more specific info of it's application and on the following markings the " N 597 ' on top of hub , the " MD ' in circle , the " RNA " , the " RDW " and the single " X " on back of the hub also any info on the Lang sticker which is different than others i have found and what this might tell.
I will post the hub shots here but for all 12 photo's with zoom i hope i don't offend by asking you to go to my listing and take a look. If you search this title on the Bay you will find it " NAVY Plane LANG Co Wood Propeller CURTISS HS LIBERTY " . Thanks in advance , Good Day
