Propeller & Markings
Blade Dia 2438 mm
Hub thickness 149 mm
Hub Dia 209 mm
Hub bore 79 mm
Bolts 8 * 12mm
Bolt circle 170 mm
Wood Mahogany
Rotation from front of plane is anticlockwise
Markings (some very hard to read)
AB7873 R
D2 P1710
VIPER ENG
N W Divers
G711 N70
10380
We have 4 squares with a arrow head above them.
At the tip of the arrow head is the letter A
At the base of the arrow 488
One square has in it AID & 7T3
One square has in it A D & 7T3
One square has in it D & 5
The last one is blank
Blade Dia 2438 mm
Hub Dia 209 mm
Hub bore 79 mm
Bolts 8 * 12mm
Bolt circle 170 mm
Wood Mahogany
AB7873 R
D2 P1710
VIPER ENG
N W Divers
G711 N70
10380
