HARTZELL is stamped into the scalloped brass sheathing in several places but there are no decals or name stamps in the wood.
The only number I found stamped in the wood is on the back face of the hub and it appears to read 15312, which I'm assuming is a serial number (or could it be a design number?) If 15312 doesn't match anything, could it be 15812? (see photo)
The diameter is exactly 95"
The hub is 6" thick (8 layers of 3/4" wood)
8 bolt holes of 1/2" diameter each in a bolt circle of 6.75" (6-3/4")
Center hole in hub is 4.4"
Outer diameter across center of hub is 9.25"
The hub doesn't show any signs of having been impressed by a metal hub flange, but the brass on the leading edges near the tips appear to have been indented from having struck small rocks/pebbles, so I am guessing it has been used.
Condition = very original. There is no indication it has been restored in any way. The tips are cloth covered over the last 15.75" of each tip
What kind of aircraft and/or engine was it designed for?
What year was it made?
What kind of wood is it made from?
What else would you like to see a photo of?
Why 95" dia. and not 96"? (Why make it 7'11" and not a nice even 8')? (Was that for for shipping purposes to fit inside an 8' box?)
Thanking you (all) in advance for any help you can give me!
