I purchased this propeller in in Belgium 10 years ago while on an antique buying trip and and shipped it back to the U.S. I cannot see any identifying marks stamped on it anywhere. It's a gorgeous propeller from something, just trying to figure out what. Any ideas? It's 12 feet long.
Is this an airplane propeller?
Before you put it up for sale, lets try to identify the prop.
Is it exactly twelve feet long or is that a generalisation. It translates into mm as 3660mm. I haven't recorded a prop of that diameter; the nearest are 3300mm, which occurs often, particularly on Imperial German Naval props; and 3500mm which occurs on another naval prop. This is only six inches different from yours. Please measure it accuarately. Also please post a close up of the brass sheathing on both sides of the prop.
The prop data would have been stamped onto the sides of the hub and sometimes on a blade. The paint surface, which is not original by the way, might show slight indentations where the paint has sunk slightly into the stamped data. Probably looking at it at a shallow angle against the light will reveal something.
When we have this info, identification might be possible.
Originally posted by Dave View PostNote also that it's a left hand thread.
For me, this prop could be French (Régy or Merville) and from the 40's or even later. Perhaps a rear prop (pusher) for a seaplane.
More photos
Here are some additional photos of the propeller.
