Fahlin Kari-Keen 96" propeller
  • Fahlin Kari-Keen 96" propeller
    Am new to this site, would appreciate any info about this propeller I just acquired. Thanks
    kari keen coupe aircraft
    Hello from Dennis in Seattle. Welcome to the site and the forum. After a quick search on bing, you can see pictures of the kari keen coupe aircraft, these are rare planes , very few were made and even fewer exist. Can you post some pictures of the prop when you have time, it would be interesting to see this prop.
    Thanks.
    Dennis Hicklin.
      Are there numbers stamped around the hub?
        Yes there are numbers on the hub. They are DES 610 and NO 185
          No listing for that drawing number in my references. Please post a photo of it and measure its length from tip to tip. It would also help if you measured the diameter of the circle on which all of the bolt holes sit. (I presume there are 8 bolt holes?)
            Photos
            Hello, Dave, I will take detailed photos and measurements of the propeller later today, and send them at that time. Regards, Bob
              Thanks.
              Dennis Hicklin.
              Hello, Have photos. can't figure out how to post on the forum. If you send me your email, I will send them ASAP. Thanks, Bob
                None of those links work.
                  They work for us when we click on them. We can send them directly to your email if you like, or we can work on it tomorrow.
                    Maybe they're password protected?
                    I'll try to upload the emailed ones, but we'll need a photo of the whole prop as well.
                      photo upload
                      Its pretty easy to upload your photos on this site, I suggest you go to the section that says manage attachments, then it lets you browse your selections, its not that complicated, that being said, here is a shot of the kari keen coupe plane that possibly your prop is associated with.
                      Looking forward to seeing the particular prop you have.
                      Sincerely,
                      Dennis Hicklin
                      Seattle Washington.
                        Icons Kari-Keen Propeller Pictures
                        [ATTACH]4189[/ATTACH]
                        [ATTACH]4190[/ATTACH]
                        [ATTACH]4191[/ATTACH]
                        [ATTACH]4193[/ATTACH]
                        [ATTACH]4194[/ATTACH]
                          Keri Keen Prop
                          Prop is 96 inches long, and the hub hole is 3 inches across
                            Nice! Whatever you do, don't try to "restore" it in any way. I think that's a fairly rare and likely early propeller.
