Hi all,
I have come across two old wood propellers, one is made by "J. Lee Simmons Wash. D.C." and it still has the gears attached to it. It looks really old and the guy I bought it from said that he thinks it was made in the 1930's. It is pretty broad and about 8 ft in length. It looks like it was made from 5 long pieces of wood laminated together. The only other thing I found is a stamp engraving of a "D80" on it.
For some reason I think the second one was made by Hartzell, but not sure if this is true. I was told that it is WWII era. It is also about 8 ft in length and it has metal plates on the leading edges with rivets. It looks like it was made from 8 pieces of wood laminated together and it has 8 holes for the bolts. No markings on it except for a "1" on one side and a "2" on the other. There are also a set of numbers near the top of the bolt holes that say "36019".
I cleaned both up slightly and am thinking of putting a coat of linseed oil on them.
Any help with ID/age would be greatly appreciated.
I'm also looking for someone that could restore them professionally. I'm in the central New Jersey area.
Thanks in advance.
Thanks in advance.
