I wonder if anyone can help find which aircraft his prop is from.
it's a REGY propeller, Serie 240 No 649 ( also has either B1 or R1 stamp)
other side has A2 45 Op At
Helices FFR Paris ( circular decal)
Hub 160 diameter, 95 thick
8 holes 119 PCD, hole diameters 9 m
central bore47mm
Prop is 212cm diameter, but may have lost a bit on the tips.
The only similar one i can find is serie 245, for a caudron G3
central bore47mm
