I've recently acquired a propeller section.
Specifications:
10 bolt holes.
11 laminations.
Bolt hole diameter 15mm
Axle diameter 95mm
Space between bolt holes is 70mm
Props boss diameter 310mm
Boss thickness 210mm
It must have been from a very large prop.
Seems to be german(light colored)
Markings are fainted.
The edge is metal sheeting
Seems like a pusher propeller.
Are there 10 bolt props used in ww1 and on which type of airplane?
Kind regards,
Specifications:
10 bolt holes.
11 laminations.
Axle diameter 95mm
Kind regards,
