I have propellers with a Bristol & Colonial Aeroplane Co Ltd stamp on it, They also have numbers 5120, and B&C 4387 on, can anyone tell me what aeroplane they could be off? Thank you, debbie
Identification info
Hi Debbie,
Welcome to the forum.
You haven't given us much to go on but the serial number B & C 4387 indicates a date of about three months into 1917. The company was called the British & Colonial Co until just after the end of WW1 when it became the Bristol Aeroplane Company.
I don't know to what 5120 refers. It is not a B&C drawing number and not any other WW1 recorded drawing number. A drg no would identify for which aircraft type the prop was made. I should add in parenthesis that although there is no record of 5120, it occurs in the drg nos issued to the Lang Propeller, although with no recorded use found so far.
There should be lots more data stamped on all four sides of the hub. Can you read any of it? Perhaps you could send us photographs? Ideally we need shots of the complete prop, both sides, the B&C decal, a drg number such as P3023, and the diameter and pitch of the prop, stamped as (for example) D2650 P2320. We need the photos at a good resolution, well lit and in focus. If this sounds obvious, you'd be amazed at some sent to me.
Thank you for your reply, I have had another good look and have found the following info:
S (orHp
D500
P400
L Rhone
P (or001
4387
51?0
There are the letters ADP within a circle
AID - the I could be a 1
SLJ - the s could be an 8
These six letters are within a square box
I'm sorry Bob I'm useless with computers so will have to get help if you need pics!
Thank you again for any info you can provide,
Kind regards
Debbie
Good Morning Debbie,
Your data provides the answer; It translates as follows;
S (or Hp probably 90hp, possibly 80hp
D500 D 2500, the diameter of the prop in mm
P400 P2400 the pitch of the prop in mm
L Rhone The type of engine, a French Le Rhone
P (or 001 The drawing number of the Prop, P3001, where P indicates a Bristol design and 3001 indicates it is for use on the Bristol Scout
4387 The serial number. 2765 is also known. 2628 is owned by the Imperial War Museum
51?0 I don't know
There are the letters ADP within a circle This is the airworthiness stamp of the Royal Navy and tr. as Air Dept (of the RN) Passed
AID - the I could be a 1 AID is the airworthiness stamp of the British Army. I have not seen both Army and Navy stamps on one prop before. It indicates the Aeronautical Inspection Department.
SLJ - the s could be an 8 The identity of a specific inspector. It is likely to be 8LJ, although this number has not been recorded before. Known stamps used at Bristols' were 32, and OU5
Your prop is very probably made of walnut, although mahogany is possible. The government paid £12-5s-0d for it.
So your prop is very probably one of a batch of replacement props made by B&C in early 1917 for their Bristol Scout, which was used by the RFC on the Western Front in France and by the RN in the Aegean and Mesopotamia. It was ubiquitous in France. Lamberton records that every RFC squadron had two or three.
Smiley faces are always welcome!
