I have a beautiful antique aircraft propeller and I would like to know more about it's history.
It has several markings and you can see those on the enclosed photos that I have attached.
I am interested in knowing what type of aircraft and engine this propeller came off of.
Here are the details:
The center section of the prop has a three and 1/4 inch bore. It is surrounded by eight bolt holes of 3/4 inch diameter and spaced three inches apart around the circumference. The bolt holes are eight inches in diameter and the entire hub measures 11 inches in diameter.
The markings are quite clear and the first marking is an anchor symbol with a "U.S." stamped around it.
The second marking says "MATTHEWS BROS MFG CO."
Third there is "N.O. 1050"
The next line reads "9'6" X 5'7"
Lastly it is stamped "R6"
Thanks for your help!
Sincerely,
THUDDRIVER
Edit: Photo added
Sincerely,
THUDDRIVER
Edit: Photo added
