Hi all
funny thing, my father in-law had this wooden Propeller (which had been cut to the hub only) and a clock on the face, I always admired it and showed my interest, well I guess he decided to finally give it to someone who would appreciate it.
I really am more interested in the history of it than value, as i really like it and wish to display it.
I have looked around this fantastic forum, but the info and knowledge is overwhelming.
so i was really hoping some of you may be able to help.
I measured it to try to match it up using the list found on the site.
hub diameter 8 1/2" (I measured where I could see the impression of the metal hub)
8 bolts holes that measure 5/8"
center bore 3 3/4" (measured at the front, as the back side has been bored out)
hub thickness 5 7/8"
bolt circle 6 5/8"
give or take with all measurements (should close, within a 1/16)
the only markings i could find are a 1 and 2 stamped on either side of where the blades would start
there is also the number 20039 stamped on the outer circumference of the hub (engine side)
any help would greatly be appreciated.
thanks again, great site
bolt circle 6 5/8"
