What plane used this prop? The bolt size is .5 inch. The bolt circle is 5.9 inch. The bore has been rasped out to accommodate the clock. Hub thickness is calculated as 5.5 inch. This may have expanded due to moisture. "Heine Propeller" is clearly stamped with an oval blue stamp on one side and dimly stamped on the other side. On the left side appears to be figures 1119 1160.
On the right side are letters and figures read as GEPRUFT ERS ART 2
We are sure of the left side figures unless we are reading them upside down.
