In 1970, i acquired a dark, wooden propeller with brass-colored sheathing on the tips and leading edges. My father claimed it had been hanging in a bar for several years, accounting for the 3/4-inch hole near the edge of each blade. The finish is fairly glossy, so it may have been varnished by a previous owner.
The hub has 8 holes, and the bolt circle is exactly 8 inches. The bore hole is 3-and-an-eighth or 3-and-a-sixteenth inches in diameter.
Markings on the hub are mostly difficult to read and do not photograph well.
The topmost letters seem to say Marin (indistinct) followed by a clearer USP, and then more entirely indistinct lettering.
Below that is a very large and clear N-9524 with traces of gold remaining in the recesses.
Below that is 10' 0" RH, which is clearly the length and direction of revolution.
The next two lines below that are barely legible and appear to be:
S.E. 5171
T-5-L
I seek your expertise in identifying the age, maker, and type of aircraft on which it was used. Many thanks.
S.E. 5171
T-5-L
