Hi, we have 2 mounted propellers. One being from a Sopwith Camel? and the other from a German aircraft that was shot down etc. by the source in WWI.
The Propeller
HUB: 8 Bolts
IDENTIFICATION MARKS:
AID (Aeronautical Inspection Department)
77T
A50
77T
HUB IDENTIFICATION MARKS:
D.W.G. NO. 1708
FRENCH TYPE
BDSS
O/D E 15 GP II
G.A.C.
Z762?
IDENTIFICATION DECAL:
..... AUTICAL CORP
.....DON (?LONDON?)
G?...AC
SPECIFICATIONS:
CENTER BORE DIAMETER = 70mm or 2.756 inches
BOLT HOLE DIAMETER = 11mm or 0.433 inches
BOLT HOLE CIRCLE = 151 mm or 5.905 inches
DIAMETER OF HUB = 300 mm or 11.81 inches
HUB THICKNESS OR HEIGHT = 145mm OR 5.70 inches
The Propeller
HUB: 8 Bolts
77T
A50
77T
D.W.G. NO. 1708
FRENCH TYPE
BDSS
O/D E 15 GP II
G.A.C.
Z762?
..... AUTICAL CORP
.....DON (?LONDON?)
G?...AC
SPECIFICATIONS:
