propeller id
  • propeller id
    I have acquired a wood propeller and need help identifying.
    Liberty Motor Lang Products
    PNA USN and the Anchor marking
    NO.5109 DRG NO. SE5090 LW HP 370
    Pitch 6.65 Dia 8-4
    On the side of the Hub stamped N369x
    Also stamped are the letters RDW
    I do not believe the prop was ever installed there are cork plugs in some of the mount holes.
    Any help will be appreciated.
    Jim Renwick
    770-827-5952
    If the hub is around 4" (or slightly less) then it's almost certainly part of a 4 blade combination, where 2 of them were stacked together to form the 4 blade. The most common usage for that was the Curtiss HS 2L flying boat employed by the Navy in the late teens and used for a variety of operations following WW1.
      Propeller ID
      Thanks Dave
      Any idea what the RDW N369x and LW Indicate
      Thanks Jim
