While on a recent visit to Ireland I found a clock. It appears to be made out of the central hub of a wooden propeller. I think four blades, two have been cut off, and the first few inches of the remaining two forn the legs of the clock. The construction is of seven pieces of laminated wood, I think mahogany. It carries quite a few numbers etc on the back. The clock is set in the enlarged hole where the shaft will have passed through the hub. The inscriptions are
WD with a downward pointing arrow, and AID25, then 18687, BE2C RAF 1A
T7448 then DARR AOO Motor Eng Co Ltd London.
I bought it because its shape fascinated me, though it is in a bit of a mess, and needs some careful restoring. Is it worth doing? Any ideas what plane it was made for, what year, anything to help me find out what I have found.
