I recently purchased half of an old wooden prop (including the hub) in a junk shop in London, because I was pretty sure it was from a WW1 aircraft. It was made in England for a 140HP Hispano-Suiza, and I initialy thought it was from an SE5A, but a bit of internet reseach, and this fantastic website and forum has given me a bit more information. It is not in very good condition, but all the writing and numbers can still clearly be seen. The manufactures transfer of cursive gold lettering is also complete, although now almost the same colour as the wood. It reads "Made by Mann Egerton & Co. Ltd, Aircraft Works, Norwich, England". Mann Egerton & Co. Ltd., Aircraft Works, Norwich is also stamped on the blade close to the hub, and twice on the front of the hub at right angles to the blades. Under the hub, it has
140HP Hispano-Suiza
RH Tractor S7
D2450
P2132
I would guess that it is for an early (because only 140HP) SPAD VII (S7) made in the UK by Mann Egerton, diameter 2450mm, Pitch 2132mm.
There are three AID stamps, one on the remaining blade, AID 21R, with an S stamped above and below it, and two on the remaining stump of the other blade, both reading AID 65J.
Above the manufacturers name that is stamped into the blade near the hub are the numbers MI06I and P302. The P302 has a line through it. Can anyone tell me what these number might mean? I can post pictures in the next couple of days.
Thanks for a great site and forum.
Cheers,
Mark
140HP Hispano-Suiza
RH Tractor S7
D2450
P2132
Cheers,
Mark
