Identify French Propeller
  • Identify French Propeller
    Hello all forum members,
    can anyone help me to identify this French propeller?
    Probably it is a propeller from a Spad VIII?
    Diameter is 265 cm. Markings on the propeller:
    ARE
    200 RN
    Serie 573
    N 13824
    Numéro 13824
    L - I
    SFA
    Many thanks on forehand!
    Greetings,
    Gert de Leeuw
    Actually, I see it listed for an A.R. L1 with a Renault engine, which probably explains the "L1" stamping and the "RN 200". It's a Levasseur design and has the typical Levasseur shape.
    Here's the page from the AEF listings in 1918.
      French propeller
      Hallo Dave,
      many thanks for your quick reply and answer. Now i understand that
      'ARE' stands for Avions Renault, and the information on the propeller is according with your attached file. Enclosed a picture of the Dorand AR1
      with 190 / 200 hp Renault engine.
      Kind regards,
      Gert
        From a STAé listing from second half of 1917, Levasseur serial 573 was approved for Dorand aircraft AR1 2A2 fitted with a 170HP Renault engine. Another listing, from Gorrell's history of AEF (the one posted by Dave) is from a bit later and shows more approved models (L1, L2) and a 190HP engine. So, yours, with its 200HP Renault engine has to be late (1918 or later).
        "AR" means "Avion de Reconnaissance". French military used 3 letters to identify aircraft on propellers. There is no other aircraft with A and R as two first letters. So, it have to be a Dorand. But what about the E? A mismarking for 2, as E and 2 speak similar in French? Another possibility is it is a E for "Evacuation": on Wiki page ( http://fr.wikipedia.org/wiki/Dorand_AR.1 ) you can read there were 6 Dorand converted in "avions-ambulances" (~ sanitary aircrafts), that is Evacuation aircrafts in military language (hold the mouse on the words "avion-ambulance" on Wiki page). The note "3" on this line refers to "Le Trait d'Union", which is a highly credible source of information. This interpretation is consistent with the 200 hp Renault engine (entered in service in 1918 ) and the fact your prop has two sets of markings, very visible on DC_0016.jpg picture : it may be a AR1 2A2 prop re-approved for a sanitary aircraft with a 200HP Renault engine.
        Can you tell me which letter is after SFA stamp which is near "d 2"?
