prop id
  • prop id
    i have a propeller and i would like some info on.
    it has copper or brass tips,it is 8'4" long, 4" thick
    the center about 2 5/8",there are 8, 3/8"holes around the center hole
    on the left side of the center there are the letters and numbers in three rows
    SC11458
    then what looks like a four leaf clover with no stem
    1
    on the right side of the center are the numbers 1457, on one line
    behind that,going up and down, are 8'-4" D-5'-0"P
    i think it is german
    i picked it up in 1973,to hang on the wall in our gameroom. my dad was in the
    air force from 48 to 52, he loved it. he cleaned it, and put a clear coat of
    something on it. he just sold his house, so now i have the prop in my gameroom. but, when he cleaned it, the german swastika, the eagle standing
    it, was gone. he said, no american would have that symbol in their house.
    thanks
    It's not German. The markings and the clover stamp are all typical of U.S. built propellers, and the "SC" in the SC11458 stands for "Signal Corps". The diameter and pitch are stamped in feet/inches rather than millimeters, which would be typical for a European built propeller.
    The sizes you give suggest that it was either used on a Curtiss OX5 engine or possibly a Hall Scott A7A. You could eliminate one of those by measuring the bolt hole circle diameter and comparing the hub dimensions to those listed on this chart.
    Can you post a picture of it?
