I have 2 Paragon props, one is all wood, the other has the copper leading edges. The all wood prop is in original condition, and the copper clad prop has been re-conditioned (not very well done, heavily sanded, some markings gone or hard to see). The reconditioned props markings are similar to the close up you have here on the forum, I can make out the "right hand, length and pitch, and 4 digit number". The other side of the hub has a "SC number and 1 circle with the AID C2 inside". The un-restored prop has 2 of the circles and 3 small rectangle stamps, it does not have an SC number. So, is there any significance in the lack on a Signal Corps number? Does anyone know if the circles and rectangle stamps are from the manufacturer, or possibly later inspection stamps? Also, the un-restored prop has a very small stamp that looks like it is on your as well, I can't make out the first several letters but appears to end in "MOND". Any idea?
I also have a Hamilton Aero prop, very similar to the one listed on ebay right now. Other than the hub diameter (8 inches) all the measurements point to an OX5 engine, does anyone know what type aircraft these were used on?
Thanks, Dave
Thanks, Dave
