Hi, I am trying to identify a possible "Jenny" propeller. It has a stamp on the back that is worn, in part it has Curtiss Wright and ? City Iowa on it. The prop is only about 5'10'' and resembles the "tooth pick" style. Also suspicious is that the hub has only one center hole and two bolt holes, while the pitch is very flat with a total thickness of less than 2 inches. I will try to get a picture posted. I am fishing for information and looking for a source to identify the stamp on the back. Thank you for any help! Jeff
curtiss wright JN-4 prop
Solved
Thanks for your input. I discovered that this 6 foot fan blade was a early 1900's Winco Wincharger wind mill that was used to charge a battery and power household lights. It is for sale at an antique store as a Curtiss Wright JN-4 toothpick prop. This is a great website, thank you. Jeff Alexander
