My mother has obtained a propeller of unknown origin and we'd like some help identifying it please. It has the code DR66480 stamped into the hub face but no other markings visible anywhere. It has 10 equispaced hub bolt holes, which from a quick look on the internet would seem to be unusual. I have the following dimensions for it:
1. Tip to tip prop length is 74"
2. Hub bolt hole diameter is 3/4"
3. Hub bolt hole PCD is 5 1/2"
4. Centre bore diameter is 2 5/8"
5. Hub thickness is 3 5/8"
Any help would be gratefully received.
Si.
Si.
