Hello All,
This propeller came with a (the) Boulevard Engine of 1910. The engine is about 20 to 25 HP four cylinder inline Overhead Cam with the thrust bearing for Tractor installation. The total weight of the engine is 85 pounds dry.
There are no markings whatsoever on the propeller but the metal hub flange is stamped S.&.F. It appears to be made of Mahogany with four plys. The airfoil is almost symmetric with the maximum thickness at 50% chord. It is nothing at all like any Clark or NACA airfoil. There is no leading edge protection. The rest of the hub is still frozen on the crank of the engine.
I vacillate between thinking that this is original with the engine and thinking that it is a later replacement. Arguments for it being original is the primitive airfoil and constant chord. Arguments against is the small diameter. But then, the engine power is very low and the hole and bolt circle are very small which argues for a small propeller.
Diameter: 72”
Pitch From Measurements and design exercises is About 50”
Engine RPM (1911 Literature) 1200
Engine HP (1910 sizing) 20-25
Chord (constant) 5 ¼”
Thickness at hub 3”
Hole: 1 ¾”
Bolt Circle 3 ½”
Bolts 6, 5/8”
Flange Diameter 4 1/16”
[/img]
Diameter: 72”
Thickness at hub 3”
Hole: 1 ¾”
Bolt Circle 3 ½”
Bolts 6, 5/8”
