OK, If we are looking at prop identification then try this one.
The two blade wooden prop is in Australia. It is marked Curtiss AD 543 LH D2520 P 1580.
The LH probably indicates that it is a pusher prop.
Curtiss was probably the maker. It was probably on a Curtiss engine.
The only aircraft, 'airplane' if you like, that it may have been was a Curtiss MF Seagull seaplane, later designated a Curtiss 18 Seagull. We had two here in Australia but both were off the register by 1925/26.
The engine in the Seagull was probably a Curtiss C-6 of 160 hp.
Could it be that D2520 means drawing # 2520 and P 1580 means
prop # 1580 in a production line?
AD 543 I cannot guess.
Can anyone with more knowledge help ID the prop. Do I have part of the story? Or am I guessing too much.
R16
R16
